Ok so I have this Proview 19" monitor that the label on the back got ripped off of, so I have no clue what the proper model # for it is supposed to be. I ran Everest, Sandra, PC Wizard and Belarc Advisor and this is the best they all came up with:
Everest
Monitor Properties
Monitor Name Plug and Play Monitor [NoDB]
Monitor ID PTS076D
Manufacture Date Week 19 / 2005
Serial Number F6RZXXXXXXXXU
Max. Visible Display Size 38 cm x 30 cm (19.1")
Picture Aspect Ratio 5:4
Horizontal Frequency 30 - 80 kHz
Vertical Frequency 60 - 75 Hz
Maximum Pixel Clock 140 MHz
Gamma 2.50
DPMS Mode Support Active-Off
SiSoftware Sandra
Monitor/Panel
Manufacturer : (Standard monitor types)
Model : Plug and Play Monitor
Maximum Resolution : 1600x1200
DPMS Energy Star Compliant : Yes
PnP/DDC Monitor Data
Manufacturer : ProView Technology
Device ID : KDS 19" LCD - K917s/K915s/K9b/K9s
Serial Number : XXXX4F16
Date of Manufacture : Saturday, May 07, 2005
Type : RGB colour
Display Size : 19.1 in
Horizontal/Vertical Display Size : 38 cm / 30 cm
Input Signal Type : Analogue 0.7/0.3V
Gamma Factor : 2.50
DPMS Modes Supported : Off
EDID Version : 1.03
Established Timings
Mode 0 : 720x400 70Hz
Mode 1 : 720x400 88Hz
Mode 2 : 640x480 60Hz
Mode 3 : 640x480 67Hz
Mode 4 : 640x480 72Hz
Mode 5 : 640x480 75Hz
Mode 6 : 800x600 60Hz
Mode 7 : 800x600 72Hz
Mode 8 : 800x600 75Hz
Mode 9 : 832x624 75Hz
Mode 10 : 1024x768 87Hz
Mode 11 : 1024x768 70Hz
Mode 12 : 1024x768 75Hz
Mode 13 : 1280x1024 75Hz
Performance Tips
Warning 300 : Unknown monitor. Install the driver for the monitor (or similar model) for optimum performance.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
PC Wizard 2010:
Monitor Type : ProView Technology
General Information :
Product ID : PTS076D
Serial Number : F6RZXXXXXXXXU
Manufacture : Week 19 of 2005
Video Input Type : Analogic in 0.7/0.3v
Max. Horiz./Vert. Size : 38 cm / 30 cm
Monitor Size : 19 inches (estimated)
Aspect Ratio : 5:4
Gamma Factor : 2.5
DPMS Active-Off : Yes
DPMS Suspend : No
DPMS Standby : No
EDID version : 1.3
Video Modes Supported :
Mode : 720 x 400 @ 70 Hz
Mode : 720 x 400 @ 88 Hz
Mode : 640 x 480 @ 60 Hz
Mode : 640 x 480 @ 67 Hz
Mode : 640 x 480 @ 72 Hz
Mode : 640 x 480 @ 75 Hz
Mode : 800 x 600 @ 60 Hz
Mode : 800 x 600 @ 72 Hz
Mode : 800 x 600 @ 75 Hz
Mode : 832 x 624 @ 75 Hz
Mode : 1024 x 768 @ 87 Hz interlaced
Mode : 1024 x 768 @ 70 Hz
Mode : 1024 x 768 @ 75 Hz
Mode : 1280 x 1024 @ 75 Hz
Belarc Advisor:
Proview 19.1 [Monitor] (19.1"vis, s/n F6RZ55020246U, May 2005)
Even though it says "PTS076D" (which would lead you to think it's a 17") it's definitely a 19" monitor. Interesting that Sandra reports a different serial number, and thinks it's a KDS as well. It's definitely not a KDS, at least cosmetically. I looked up all the KDS model numbers Sandra thinks it is, and none of them "match" this monitor. I can try to take a picture of the front of it, if it would help. Proview's website is pretty worthless, and their phone number is disconnected! Any help is appreciated!
If this works, here's pics:
http://yfrog.com/bhimg8971tj
http://yfrog.com/bhimg8973jj
Everest
Monitor Properties
Monitor ID PTS076D
Gamma 2.50
SiSoftware Sandra
Monitor/Panel
Type : RGB colour
Gamma Factor : 2.50
EDID Version : 1.03
Established Timings
Performance Tips
PC Wizard 2010:
Aspect Ratio : 5:4
Gamma Factor : 2.5
DPMS Suspend : No
DPMS Standby : No
EDID version : 1.3
Belarc Advisor:
