My computer Duron 600 does 900mhz. At idle the temp is only 38C. It does 950mhz and at idle the temp is only 41C. I tried to boot at 1000mhz and I got all the way to the bluse screen with the mouse cursor. It just locks right there. I have noticed at 900mhz and at 950mhz sometimes there is a slight lag at the same place. I know it is not the temp because when I rebooted the temp was only 43C in the bios. Do you guys have any suggestions? My vitals are below. I did up the voltage to 1.85. Thanks!
