I first setup a system with:
Accelertech (Rioworks) HDAMC
Dual Opteron 250's
SilenX 600W Power Supply
4 GB OCZ PC3200 Registered ECC Memory
ATI 9600 Sapphire AGP Card
I couldnt get windows to install... it would keep saying it had trouble copying file.xxx. I know the CDROM and hard drive and cables are fine, but I changed them all out jsut to make sure and the problems remained.
I then ran memtest and it was failing with the memory. So I RMA'd the memory, but the new memory they sent me still had the same issues.
So I replaced the motherboard, RAM, and PSU
Now its:
Iwill DK8N
Dual 250's
Antec 550w Power Supply
512 MB Corsair Registered ECC Memory
I still get errors in memtest. I was able to install XP without any errors. But after I installed the IOAPIC driver, rebooted, and started to install the nforce drivers, the system just rebooted and wont boot anymore.
I also notice that at 1600x1200, there is some tearing on the screen. the video settings are correct and that is the default resolution for my Dell 2100FP. Could it be possible a bad video card could cause all these problems?
Please help me out if you can.... Thanks!
Dual Opteron 250's
Now its:
Iwill DK8N
Dual 250's
