- Mar 26, 2005
- 4,094
- 123
- 106
Well I was running very stable at 3.0GHz but now it's time to go higher...
I left everything on auto in BIOS and was able to go to 3.25GHz. Anything higher and the system would not boot. I then went up higher and higher in small increments increasing the voltage with various results.
I was eventually able to achieve 3.75GHz at 1.362 vcore. My temps are around 47 and 38c in RealTemp right now(idle)... and around 52c load.
I dont want to increase the voltage since the 1.362 is max for this CPU according to specs?
Any advice on how I can go higher? My mobo model is in my sig. Thanks very much.
EDITED...
EDITED...
