Zorba
Well my Bro hosed his computer, and he of course wants me to fix it.
Here is the problem: When booting up the computer will boot up, POST, run the Autoexec.bat, then pauses for a couple of seconds (like it would for the registry scan), then it reboot (by itself), when it comes back it asks you to go into Safe mode, etc.
I ran scanreg in dos, and it said that the registry was fine. So I have no idea whats wrong with it. (BTW: It does boot into Safe mode just fine) He swears he didn't do anything to it (yeah right), so I have no idea what could be causing it. It had been running just fine for 6 months, before this.
His system is:
Winblows 98se
MSI K7T Pro
DURON 700MHZ
Mwave 128MB PC133
WD 20.5GB ATA/100 7200RPM 2MB OEM
Guillemot 3D Prophet II MX 32MB
PANASONIC 1.44 FLOPPY DRIVE (The floppy control on his MoBo is dead, so his computer can't use a floppy)
48X EIDE INT CDROM
SOUNDBLASTER LIVE! VALUE OEM
56K/V90 INT PCI WINMODEM W/VOICE
Vantec Socket A Cooler
Iomega (Plextor) 12x10x32x burner
Probably (not really sure) generic 250W PS (it came with the Aopen case, seems to do the job)
He has Via 4-in-1 v4.25
Whatever BIOS came on the motherboard
I want to try to flash the BIOS, but since the floppy doesn't work, I am not sure how I'd be able to do it. If I can't flash the BIOS, I am going to RMA it for the bad FDD controller.
Things I have tried:
Pulling out SBLive
Pulling out everything besides want is need to boot
Booting off a CD bootdisk (to reinstall windows on top of itself), but the computer locks up when booting off the CD for some reason.
Thanks for the help,
BTW: His computer has been running for about 6 months just fine, until about a week ago.
His system is:
Winblows 98se
MSI K7T Pro
DURON 700MHZ
Mwave 128MB PC133
48X EIDE INT CDROM
Pulling out SBLive
