My computer is annoying me. It will run for about 20 minutes and reset itself. I'd really appreciate if someone could help me, so i'll try to describe the system and a little history of my problems with it.
I put it together a little less than a year ago. its a Slot 1 PIII 667. not overclocked, seems to run cool enough. started out with an A-Trend motherboard which later experienced BIOS problems and now has been replaced with a Sanyo i think. originally it had 128 megs of pc 133. that burned out in the old motherboard, and was replaced, plus an additional 64 meg chip was added. I've got a 32 meg ATI video card, vortex 2 sound, 20 gig hd, and windows 2000.
About a week ago it started to reset itself once in a while. Also it came up with a blue screen fatal error like i used to see with win 98 once in a while. having seen weird memory errors when the first chip went, i looked at that first. when i took the 64 meg chip out the problem remained, so i took the 128 out and put the 64 meg chip in the first slot. the computer ran, albiet slowly,for a day or two with no problem. assuming i had found the problem i went ahead and order a new chip that should arrive tomorrow. then today it started to reset itself again. Also i should note that things dont always seem towork right after it resets itself, explorer windows don't want to pop up, although it seems like it is running under task mannager. So anyway, i don't know what to do, i don't want to put the new chip in and burn it out. could my power motherboard or power supply be ruining things. I did have a bios get fried or ruined on the first one. Or is windows to blame? Or is it something more bizare like the humidity of the summer in my basement bedroom? Thanks a lot for reading this far and for trying to help. I'll try to reply to any questions, assuming my computer will let me🙂
