Info:
1998 Oldsmobile Intrigue
Scenerio:
Two days ago I disconnected the postive lead on the battery to hook up a wire for my speaker amp. The nut stripped, so I decided not to install the wire. I tightened the nut back down and gave up on the rest of the installation. Came back 2 hours later to start the car, and I find that the steering column is locked down, the brake will not move, no power goes to anything and it doesn't come on.
Symptoms
1. car won't start; doesn't turn over
2. the gauges all move and then return to the idle positions
3. stereo will not come on; has powered up twice though, and remain powered until i tried starting the car again
4. lights are dim, including headlights
5. footbrake(pedal), and steering will not budge
What I've already tried
1. Jumpstarting the car. Normal jump did not work, and letting the other car run for 30 minutes while charging my battery doesn't make a difference.
2. I tested the voltage across the alternator... 10V
3. Battery Voltage is 13... I assume that just an RMS on the DMM though... so let's say 12
4. Ohm'ed out all the fuses in the engine and in the cab. Visually inspected for breaks and found none.
5. Chevy dealer said the security light would be lighted on the dash if the security system was activated.... it is not lit though.
6. It's been sitting like this for 2 days now and I've tried each night after work to start it up, but there is no change in the condition.
I realize this should be taken to a dealer or a mechanic, but I have $100 to my name and the dealer has already quoted me ~ $200 just in labor... parts and towing fee not included. This is my only method for getting to work, so I'm having to rely on a friend to come pick me up every morning. If anyone can help or give suggestions, I'd really appreciate it.
Scenerio:
Symptoms
