- Jun 14, 2004
- 9,687
- 36
- 91
Ok, I am looking for a search engine to search through files on our vault. However, I need it to do something specific which I will explain below.
On our X drive we organize files by X:\<State ID>\<Case #>
All of our case numbers are a certain length, for example LA0403234 would represent a case in Louisiana that was started in march and was the 234th case in march. CA0312002 would represent a case in California that was started in december and was the 2nd case of december. And so forth.
So, if I wanted to look for something on the X: for the case GA0309233 then it would be located at X:\GA\GA0309233. If I wanted to find something for TX9901023 then I would look under X:\TX\TX9901023.
What I am looking for is basically a quick way to type in a case number, and windows would very quickly open up the directory for the case number. The ideal way would be a small window at the bottom right of the screen where I would type in my case number and hit enter and it would open up that folder quickly.
I figure a search engine would be good, but I want it to be quicker. I would like the search engine to take the first two characters of the string so it could do a quick search through the state instead of searching every folder on the X drive. This takes a while if it is a state that is later in the list, like NY or TX.
So, lets say for instance I type in the case AL0412335, then I would want the search enginer to automatically pick up the first to charaters in the string I typed so the engine would only search in the X:\AL folder and nowhere else. I would also like it to automatically open up the case number directory and display an error message if you enter an invalid case number (like FZ0304567 or NY03124 ). Thanks
