- Mar 27, 2007
- 291
- 0
- 76
Looking for a new case has been incredibly frustrating because I just can't find one that I'd like. Hopefully the fine folks at Anandtech have some good suggestions.
My criteria:
- ATX.
- No windowed side panel, or one that is entirely glass. I don't want to see the guts of my computer unless I remove the panel.
- No extra LEDs. I will be leaving power and HDD LEDs unattached as well.
- Quiet.
- Tool-less.
- Aesthetically pleasing, although preferably nothing that screams "Hey, look at me!".
- Front panel: 2x USB 3, audio in, audio out.
- Easy to install a system into, easy to tinker with afterwards.
- Side panel easy and fast to remove and put back.
- Has room for one large dual-slot GPU.
- Good airflow with sufficient number of fans included.
- 2x 2.5", 1x 3.5", 1x 5.25" should suffice.
- Good build quality.
I will be keeping this PC on 24/7 and in my bedroom. Hence why I like to to keep noise and lights to minimum.
The closest I've found are cases from Fractal Design. My current case is from them as well but I'm not happy with the side panel it has, so I am wary of getting another Fractal Design.
Thank you in advance.
My criteria:
- ATX.
- Quiet.
- Tool-less.
