imported_blip
I’m currently downsizing my pre-built PC into a Raijintek Thetis case, and trying to determine what kind of cooling I need. I don't game (other than really basic ones) and it's mostly for home user so not expecting high temps. It will have a Ryzen 7 1700 with the stock Wraith Spire cooler and an MSI GTX 1050 Gaming with twin fans.
The case comes with 1x120mm rear fan, and space for 2x120mm on the top and 1x120mm on the bottom. It is an inverted design, so my GPU fans will be blowing toward the top of the case. The CPU cooler will be blowing toward the side panel, but plenty of space in between (Wraith is about 70mm high, and case has clearance of 150mm listed).
How many fans do I need, and which way should they be pointing? I’ve read some people say to make the top fans blow out to exhaust the GPU air. I’ve also seen some people say the opposite, in order to push fresh air toward the GPU and CPU. Do I need a bottom fan for extra air? Leave the rear fan as exhaust? The sides and front are solid aluminum, so not much airflow there, just a small mesh area on the back and the top and bottom openings.
Since I’m not really pushing the system, I’m not sure how much I need, and want to keep things as quiet as possible. Should I assume I will need to replace what comes in the case? Or are some stock fans quiet enough?
For mobo connections, my manual lists one “processor-fan cable connector,” one “front chassis fan connector,” and one “chassis fan connector”. They all look like they are 4 pin. Do I use them all, or daisy-chain my fans into one of them? Can all PWM fans be daisy-chained?
Is it recommended to get rubber mounts or pads for the fans, or maybe they will be quiet enough?
Thanks so much for all the help!
