Please help me determine my high ping problem
lariz
83
I'm trying to figure out why my ping is so high when I play BF2. This is a brand new computer I built myself a few days ago. I'm using Bellsouth DSL with a D-Link router.
Couple of things I've done/figured out:
-Set ports for BF2 on router
-Vista firewall is not the case
I've never really had any problems playing online games before so this is a shock to me, I never thought I would have these problems so early with a new computer. If anyone has any solutions that may fix this problem, please post them
Thanks in advanced.
FYI: I'm good with computers but terrible at networking and anything that involves the internet.
Neurodog
927
22
I just finished playing BF2 tonight miself and I had similar problems when I tried to play on large server with more the 40 people playing. It turns out it was my video card that couldn't handle it with the high resolution.
Neurodog
927
22
Originally posted by: lariz
6600 2.40GHz
2G RAM
7900 256MB vid card
Doubt it's my system.
Ya your right but I was currious.
So other games didn't get that high pings? or is it after installing Vista?
spidey07
65,469
6600 2.40GHz
2G RAM
7900 256MB vid card
Why not take that out of the equation and use lowest graphic settings?
This is where PC troubleshooting and network troubleshooting completely diverge. Reduce it to the lowest common denominator. You can't control your provider, so focus on things you can control.
BassBomb
8,390
i have that problem too, i didnt have it before :S, its what turned me off bf2 forever
i forwarded as many ports that bf2 uses as i could, my isp has upped to 10mbps and still no help
so i gave up
spidey07
65,469
You can't control your ISP.
Choose servers that give you a lower "ping". 140 ms is pretty good.
lariz
83
Thanks for the help guys. I guess I'm just going to have to deal with it. Like you said, you can't control your ISP.
TheTeacher
928
I had that problem and was never entirely able to track it down. It wasn't the system either (2x 7950GX2, x6800, 2GB 1066MHz Corsair XMS2, 4x 76GB Raptors.. I miss her.. =(
Anyways, what I did was go into Documents and Settings/Username and I forget exactly where is the BF2 folder, well I removed it, then restarted the game and let it recreate the folder. I had to resetup my keys but lag was gone. Actually now that I am thinking about it, something makes me think it had to do with using the nvidia software overclocker in windows was causing it, and causing packet loss.
Aarondeep
1,115
Things you can do to narrow it down:
1. Bypass your router and plug computer directly into the DSL modem
2. Lower video settings to lowest and see if the problem persists.
3. Onboard NIC could possible be the cause..
4. Run a traceroute to the servers you are connecting to: go to a dos prompt type tracert (ip-address)
Neurodog
927
22
If you ping that same game server from a dos window as aarondeep says that would tell you if it's your ISP. But could also be your router if you have 1.
lariz
83
How would I be able to check my NIC?
