Hi guys! I hope you're all having a great weekend.
I'm deciding between two labtops in the $550 range. I found these two which had the most processing power and ram I could find. They are the same price.
Gateway M-6843
Toshiba Satellite AMD
The two main differences are a 17" versus 15" monitor and the different processors...
My first question is the AMD processor as fast or faster than the Intel? I've never had an AMD before. Since both are dual cores with around 2.0gigs, they should be comparable. However, I noticed the AMD only had 1 mb of die memory versus intel's 2mbs. Will this result in a noticeable performance difference?
Secondly, what is the difference between TruBright and UltraBright in monitor specs?
I'm mainly going to use this labtop to run dreamweaver and watch some movies. No gaming here. However, I want it to have enough processing power to last a bit. I'm thinking $550 is a steal for the processing power. Everything else I've seen seems to be an intel 1.6gig with 1-2 gigs of ram in this price range. I'm just hoping I didn't miss any glaring things that should push me one way or the other.
So, which one would you advise that I purchase?
Thank you for the help,
Gateway M-6843
