Please help me build my pc
birbal
Hello Guys,
I would like to build my pc. My budget is around $700.00. I already have 17" CRT monitor. Kindly suggest me what hardware I should buy.
I am thinhking of following.
1) P4 3GHZ CPU with HT Technology
2) Intel Mother Board (Kindly suggest me model)
3) 250 GB Seagate SATA Harddrive
4) 1 GB DDR2 Ram
5) Power supply (Plz suggest me what voltage power supply I should select)
6) 256 MB PCI Express Card (Plz suggest me brand my budget is around $100)
7) Noramal Keyboard & Mouse
Gamer X,
Thanks for your reply buddy but I want to go for intel CPU only. For some reason I don't like AMD.
Planning on overclocking?
edit: nm, if you're looking for an intel motherboard you probobly can't overclock.
Originally posted by: OSX
Yeah, get an 805, Conroe Motherboard, and then drop in an E6400 when the time comes.
Think an E6400 @ stock will blow an overclocked 805 out of the water?
Dude, it says "Supports Intel Core 2 Extreme / Core 2 Duo processor" at the bottom. Besides, all 965 boards will support C2D.
Will that support DDR2-533 though? I'm not paying for DDR2-800.
I'm thinking of an ASUS P5B, because I've always had extremely good luck with ASUS. That and I've got a rather old P2B-S which kicked ass back in the day, and still runs extremely well.
Maybe this will change your mind about DDR2-800 RAM.
DDR-800 RAM
