ibex333
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
She only uses this to play solitaire and watch netflix, and streaming news and popular show episodes online, checks email, and browses the internet.
The only thing which in very important is 1080p support and smooth video playback.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Like $400 but I am trying to keep this as cheap as possible. Remember CHEAP, over speed/performance is what I need as long as I will meet the usage requirements. (read above)
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
No brand preference, but I am stuck with Intel at this point
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Yes, I already have a bunch of parts. I have a screen, mouse/kb, Windows, Hard Drive, and I already bought this barebones kit . Yes, I know the PSU is garbage and not much space for adding stuff, but she doesn't need any of it, and she wants here PC to be very small.
7. IF YOU plan on overclocking or run the system at default speeds.
Nah, no OCing for her. (But out of curiosity, does this mobo I picked support OCing?)
8. What resolution will you be using?
1080p
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
Now. Newegg ships in 2-3 days to me so as soon as package arrives.
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
No. I already have everything.
So basically in the end, all I need is CPU, DVD Drive and RAM, but I have some very important questions.
1)Does the mobo I picked support integrated graphics in a CPU? If so, just how much of a CPU is enough? Should I go with i3 or can I go lower/cheaper? Same for RAM. Just how much would be enough for her without being overkill?
Will this mobo take any regular DVD Drive? She's not gonna watch blu-ray.
Thanks very much
USA
1080p
Thanks very much
