I just bought a Gigabyte GA-7VRXP along with a AMD Athlon XP 2200(1.8 MHZ, Throughbred) cpu. I disabled the on board LAN, and sound. The memory I am using is PNY 256 PC 2100 DDR. I went to AMD's website to make check what the clock speed of my cpu. It keeps saying that I have a AMD Athlon XP 1500 + with a speed of 1369 MHZ rather than the expected 1.8 MHZ that it shoud be.
At first I thought I recieved the wrong chip but I checked Anand's latest take on the Throughbred and in the article he mentions how to make sure that you have a authentic Throughbred chip. Sure enough I opened up my computer and it checked out, I do have a authentic Throughbred(you can tell from the serial numbers). Maybe I thought it was the clock frequecy but that didnt help either and during my boot up it would still say AMD Athlon XP with out the speed etc.
I read through the manual of my motherboard and used the bios utility provided to flash/update my bios. After the update, at the boot up screen it reads AMD Athlon XP 1500 + . Again I ran the AMD CPU info program and it still lists my speed to be 1369.
Can anyone please help me in figuring out what the problem is. I just want to make sure that I it indeed does say that my cpu is a AMD Athlon XP 2200 and the clock speed is 18. MHZ. Thanks for your help in advance.
