Hi all,
I've been running my PC after an upgrade for 2 months (changed CPU, mobo and memory, but kept the video card, psu and hdd). Today it started to show an error and lockups:
After some minutes running a 3d application, it appears on screen some artifacts in shape of squares on a repeated pattern, and then the computer locks. Sometimes I have to press the reset button. The squares have always the same size and position on screen, but varies in colors with the background image. This appears only in 3d apps.
The computer is the following:
Core i5-2500k (new), Asus P8VZ68 Pro (new), Gskill ddr3 1600mhz 8gb ram (new), Radeon 4850 (3 years old) and Seventeam 420BKV PSU (3 years old). Running all default clocks.
I've not updated the drivers or anything these days (except for updating Windows 7), and the same applications that were working started failing, and the same squares in different applications.
I would like to know if there is a easy way to figure out if the PSU became faulty or the video card. I've run the Prime95 torture test for 30 minutes, and got no errors. Voltages (except Vcore) have not varied during the test, and temperatures were 87ºC, but running the default heatsink on Brazilian summer, and in games it's below 70. GPU temperatures doesn't look abnormal (below 70ºC in use).
I really want to avoid buying a new psu and a new videocard to see if it solves the problem.
In the past, I was suspicious about this PSU because it used to make some high pitch noises, but since I went from a core 2 duo @3ghz to this core i5-2500k, didn't have those noises, and I've seen a lot of users complaining about high pitch noises on high quality psu brands.
Using Windows 7-64bit with all updates. Catalyst 11.12 drivers (uninstalled and downloaded again and installed again, but no result).
Any tips about what can be this problem or which component is faulty?
