- Jun 5, 2008
- 7,096
- 3,571
- 136
I recently purchased a barebones Ace Magic S3A mini-PC with the AMD 6800H processor. This brand is known for malware running on its PCs so I don't really trust downloading anything directly from their site. Their drivers can be found on google drive with a link on their site and on their forum. The drivers come in a folder and have a separate .bat file which I assume automatically installs the drivers.
1. I have a clean Windows 11 install made with rufus. The wifi is not working yet so I need to identify the hardware (RTL8852BE) to find and install the driver. The problem I always have is finding a specific driver for specific hardware. I can't find RTL8852BE driver on Realtek's site. Do they make an automatic installer for realtek devices? What program or app do you use to identify hardware so I can find the correct drivers?
2. For the mini-PCs chipset and graphics can I just use the "Auto-Detect and Install Driver Updates for AMD Radeon™ Series Graphics and Ryzen™ Chipsets" and it will find everything it needs? What would I need to select to find the chipset for this mini-PC since it doesn't have a normal motherboard? Would it be Chipsets - Laptop Chipsets - AMD Ryzen and Athlon Mobile Chipset?
