Please help. I have a few questions/problems with my ABIT IP35 Pro.
dsg2003gt
Hello, I read through much of the ABIT IP35 pro thread in the MB forum and couldnt find the answers to this:
When in my bios and watching my voltages(and Uguru) as well, the CPU Voltage moves up and down every few seconds by .01-.02 with the most I have seen being .06. Im not talking about a constant discrepancy like Vdroop, but it actually moving up and down.
Also my ram does this as well only it goes up and down by exactly .02.
Finally my last and probably most important question is that when I change my multiplier to 8 in the bios and run 400mhz fsb the bios shows a CS of 3200ghz but in windows both CPUZ and my computer show it running at 3600ghz. I am running the version of the bios that came with the MB and the revisions dont seem to address this so im not sure what to do. CIE and EIST are enabled.
if it matters the PSU is a 550ht from seasonic and my ram is Gskill 1000 5-5-5-15.
Heidfirst
2,015
the sensor readings aren't constant but periodic & obviously you get some variance over the period of the reading plus you have sensor tolerance too.
& that's even before mentioning C1E & EIST.
CPU-Z & Windows aren't clever enough to realise that you are running your CPU at less than it's default multi & that is what they are reading & showing.
VirtualLarry
56,570
10,202
Windows gets confused when you don't use the default multi, but CPU-z should be correct. If not, see if you need to update your version of CPU-z.
You may want to disable C1E and SpeedStep.
