I have a HP Photosmart (<-----A marketing gimmick) P1000 Printer. After 4 months of rare usage, the Color Ink won't print Yellow for some odd reason, all colors seems light colored. Checked the cartridge to see if Inks are low but indicator shows it at 55%😕 so I cleaned the cartridge couple times using the self cleaning on printer meanu. Still no go. I then purchase a new high capacity Ink cartridge for a freakin $57.00, Does the same freakin Things :|. Initial prints are always light colored. Could it be a bug with the printer itself? or am I getting bad luck from Ink Cartridges? Anyone had the same problem? or owns a HP P1000 care to comment? Or could this be a driver problem?
Using WinXP PRO with latest driver from HP website. Plugged through USB.
Help would be highly appreciated.
--Scsi
--Scsi
