Hello, I'm new here and I've just finished up my newest build .I recently bought an XFX 4850 hd 1gb to completely finish my build, and it displays no video at all no bios, windows nothing. For the past 3 days I've been trying to make it work playing around with settings, configs, researching my problem, etc and nothing. I have integrated graphics and I've tried with and without them enabled and nothing. The fan starts every time and there's always one beep when I boot with integrated graphics but there is no beep with integrated disabled.
PCI is set as 1st priority to boot from. PCI latency timer is set at 64 (ranges from 32-248 64 is default). I've tried resetting the bios and nothing. I've tried multiple times to unistall the integrated drivers from device manager and nothing. I've tried inserting and reinserting the card at different times. I've also tried different pci express power connectors, and there's a molex connector on my motherboard to help power the pci slot as well. I've also updated the chipset drivers.
The only thing I haven't done is update the bios I have the 2nd most recent bios. The most recent says that it "Updates AGESA code" I have no idea what that means. But does anyone think a bios update could solve my problem?
Any help is greatly appreciated. I'll try anything I really want to get this going even if it's something I've listed just tell me how you'd do it and I'll do it exactly the same. I may have left a step out.
Also I don't have any other pc I could test this in that I'd know it'd work unless i ask my friend to try it in his (it'd be at least a week till I could).
Thanks again in advance (I'll have my set-up in my signature once i figure out how to edit that).
And Happy New Year to all.
Edit: So apparently I'm not permitted to have a signature so my rig is:
ThermalTake V5
Corsair HX-850
Foxconn A7DA-S 3.0
AMD Athlon II X4 640
G-Skill Ripjaws DDR3 2x2gb 1600 mhz (running at 1333mhz though)
Hitachi Deskstar 7200 rpm 500gb
XFX ATI Radeon 4850 hd 1gb
HP DVD Drive
Windows 7 64 bit
ThermalTake V5
Corsair HX-850
Foxconn A7DA-S 3.0
HP DVD Drive
Windows 7 64 bit
