- Jul 11, 2001
- 40,931
- 10,233
- 136
I followed the simple steps in this 2:32 YT video to disable the popup in Chrome.
Seemed an innocuous enough thing to do, but then all my Chrome Windows are black, there's no info. I reboot and Chrome is open but no windows work. Do I need to uninstall Chrome??? I'm using Edge right now, there's zero functionality in Chrome.
The reason I want to remove the popup overlay (actually just the big right side of the popup that you see an X through above) is that the whole popup including that big right side persists, covering a significant part of the screen and doesn't disappear no matter what AFAIK for something like 15 seconds, maybe more.
The video has you open a new tab in Chrome and type this in the URL bar: Chrome://flags and scroll down to Hardware Media control or something like that and change the setting from Default to Disabled and then click the button on bottom right that says something like Reset. After doing that Chrome was trashed. Must I uninstall Chrome?
