- May 14, 2000
- 37
- 0
- 0
Hi,
My computer is now up and running, but there seems to be one problem: the temperature of the CPU becomes very hot under heavy load. I'm running a P3V4X motherboard, with a PIII 700MHz (not overclocked) on an IWill slocket using a Golden Orb to cool it. The idle temperature of the case is about 35 degrees Celsius. However, after I played a game, the temp hit 70 degrees Celsius, and took forever to cool down!
FYI, i'm using the golden orb with artic silver compound. I'm really concerned about this, and would like some suggestions. You guys think I should get a new heatsink/fan combo? Any ideas? Thanks in advance.
P.S., the readings are accurate because I checked with motherboard monitor and the system bios. Also, the case and air circulation are fine (mobo temp is always under 25 degrees C).
