PLEASE HELP, COMPUTER WON'T POST, SAVE ME JEEBUS
Chubbz
1,196
OK, this has been frustrating the crap out of me for the past few days. This is the system configuration.
Iwill KK266
Athlon Thunderbird 1.1GHz
256x3 SDRAM
TNT2 VID CARD
A CD-ROM and a BURNER
A 40 GB HDD
FLOPPY
ZIP DRIVE
Antec 340 watt PS
Now, I start the computer with the monitor plugged in and everything, everythings all hunky dory, but theres nothing on the screen, i tried every single RAM placement I could think of, tried different video cards, tried different HDD, and it still wont POST!! i can hear the HDD spinning and all that good stuff. IT JUST WONT POST!!!
WHAT AM I MISSING GUYS?!! any help or suggestions would be EXTREMELY appreciated
azncoffeeboi
989
Heh, I had the exact same problem. Looks to me that your mobo is grounded to the case. Do what I did and try to run the computer outside your case. It should work.
Added Note: Whlie its in the case, try hitting the reset button after you boot up your computer. I had to do that for a while before i realized my mobo was grounded.
BTW: Jeebus was the old name of Jerusalem. In a sense, Homer is saying "SAVE ME JERUSALEM!!!" Heh... interesting, eh?
azncoffeeboi
989
Heh, im not exactly clear on how the grounding thing works.... but... it makes your computer not run. heh ... anywho.... here what i did
Took everything out of my case and I put the mobo on my table next oto my monitor. I plugged everything in (HDD, ram, video, ect)
Computer ran fine on the table. In order to keep the mobo from grounding itself to my case I put non-cunductive washers between mobo and the case.
Hope this helps
Chubbz
1,196
alrighty, i got it, thanks man! ill try it tomorrow, and thats a very interesting fact! THANKS FOR THAT TOO!! YOURE FRIGGIN AWESOME!
