PixelDeath
for starters, the specs:
AMD 64 3200+ Winchester
Asus A8N-SLI
1GB Nanya DDR400 PC3200 Ram
520w Super-Flower PSU
Gainward Ultra GeForce 6600GT 128MB (PCI-E)
1 x NEC DVD-RW 16x Dual Layer
1 x 52x CD-RW
Now, for the problem, ever since i got this new pc (a home build) it has been crashing, originally it was faulty ram, with the ram replaced i still had the same problem, and that is i get usually a screen freeze and need a reboot, and the odd BSOD which is usually one of:
IRQL_NOT_LESS_OR_EQUAL
or
PAGE_FAULT_IN_NONPAGED_AREA
after readin these and other forums i have tried several different quick fixes (11 in total) and nothing will fix it
this computer runs fine while idle on windows (i turned it on and left it for 4 hours last night) but as soon as play a game, listen to music or watch a video it crashes to one of those blue screens or freezes and all you can here is the last sound bite looping.
The first thing i tried was using one stick of ram, from this the pc did not post at all, i tried putting the ram in different slots and again it didnt boot - after speaking to the company i bought the ram off i apparantly have "Dual Memory" motherboard and it will not run without 2 sticks in.
So i moved on to updating all the drivers - and even using the beta ones - to using the original drivers from the cds. i also updated my bios which is now version 1001.
after i still had no improvement i set about removing uneeded pci cards (sound blaster audigy 2) and disabling onboard devices, namely the onboard sound.
So at this point i have no sound enabled, all my startup items are disabled through msconifg (another supposed fix) and im STILL getting problems with the games i have installed.
Any help would be gratefully appreciated, thank you! 🙂
Asus A8N-SLI
1 x 52x CD-RW
or
