My problem is here, and it explains why Juno's premium dialup service is horrible!
I basically can't send emails in eudora, or any other email client i suspect, because of my isp, juno, not allowing me to go through their mail server
Therefore, to try to get around that, i tried using yllus's advice: (this thread has some more info)
I'm trying to set up and run a local mail server using this software, ArgoMailServer. I am running Windows 2000 Professional with Juno Premium DialUp as my ISP @ 56k.
I wish to use Eudora as my email client to import and send out my Yahoo! mail. I can currently retrieve my POP3 messages from Yahoo using the incoming server "pop.mail.yahoo.com"-no problem there, works fine.
I want to be able to send emails, however from Eudora. So I decided to set up a local email server but when I try to send an email, your mailserver software gives me the following:
"Fatal SMTP error: Will Bounce Back. This appears to be a bounced message. Will delete to avoid loops."
This is after many attempts to connect to the servers (i've tried to send to yahoo, hotmail, and aol).
I've researched this problem a lot with no luck. I am aware that my Juno ISP doesn't make available its mail servers and rather allows only its users to create and set up an "@juno.com" email account that would allow sending and receiving even in email clients using POP3. I do believe this has something to do with my ISP, as I have set it up on other machines using LANs and other ISPs and it has worked flawlessly. It is an excellent piece of software.
Thanks in advance, your help is much appreciated
