Shattered Skies
My old rig's Mobo went bad, so yesterday I rebuilt the system to make it slightly faster. I added a new type of mobo, memory and processor, and then had Windows run a quick "Repair Mode to see if anything on the OS was corrupted when the Mobo went bad. I also ran scandisk to see if any of my info was corrupted.
Now I'm having a strange problem when trying to restart the computer. Please note that other than this the system is working flawlessly.
In windows, after I completely shut down the computer I can turn it back on without a problem, but only after I unplug it for 5 minutes. Also, if I try to restart the computer from Windows, the system successfully exits the OS, but then the screen goes black and the monitor goes into standby mode (orange light). When I reach this point I need to unplug the computer and let it sit for five minutes before I can turn it back on. In other words, a soft boot is impossible. Needless to say, this becomes rather annoying when a new piece of software asks for a restart.
A few items of note:
-I have the most current system mobo BIOS
-Memory is working properly
-reattached the vid card to assure proper placement
-PSU is sufficient for new items
-Heat is registering within normal tolerances
-The motherboard Post Code always (even in Windows) flashes "FF", and I never hear the 1 beep post during boot-up, but I can enter Windows and everything within the OS does work properly.
-reset button is not working any longer
-when booting the system, Epox motherboards go through a quick diagnostic that shows various items and temperatures being checked. Eveything shows as "OK", but I do get one warning: "Notice- CPU has changed since last session. Please adjust settings in CMOS, Save and Reboot. To bypass this message and continue to Windows, press F1" In Windows, the processor does show correctly in the System Information tab
Any suggestions would be appreciated. Thanks!
WinXP Home
AMD Sempron 2800+
Epox 8KDA3I mobo
512 MB OCZ DDR 400
40 GB WD 7200 RPM DH
16X DVD-R
Soundblaster Audigy 5.1
Old specs for computer that were changed out:
Asus A7V266-E mobo
512 MB Crucial SDRAM
AMD 1900+
WinXP Home
AMD Sempron 2800+
Epox 8KDA3I mobo
512 MB OCZ DDR 400
16X DVD-R
Asus A7V266-E mobo
AMD 1900+
