Vigilante82
Hey,
A few days ago, I started getting many random errors in windows. Sometimes my computer would randomly reboot itself or when I was running programs I would get booted back to windows for no reason. When the reboots happened, I would hear the clicking noise that is made when I turn the power on my computer on or off. At first I thought that the problem was a software one as I just made my computer 2 months ago and it has been working perfectly since then. The problem is, even after I formatted my hard drive, the rebooting still happened. I began to suspect that the problem was a hardware one. When I formatted my computer a second time, I couldn't even install Windows Xp. I kept on getting errors that told me that certain files couldn't be copied properly. Eventually, I started getting these weird error messages that stopped the installation completely. They were some page fault errors if I remember correctly and they showed some codes that looked something like 0x00005 and stuff like that.
I took out every component in my computer except for the bare essentials: Motherboard, CPU, RAM, Vid Card, CDROM, HD, but the problem still exists. A friend of mine suggested that the problem might be with my RAM. Perhaps it has become faulty??
I was wondering if you guys can help me figure out what is causing these problems. If it is the RAM, is there any way I can test to make sure it is the RAM that is causing the problems? I only have 1 computer that supports DDR ram so I can't really test the RAM on another system. I also only use 1 stick of ram as well so I can't just remove 1 stick and test the other. I have warrenty for my RAM so if I can find out for sure that its the RAM that is causing the problems I can get it replaced.
Any help would be greatly appreciated! Thanks!
My SPECS:
Athlon 1900+ XP
Epox 8KHA+
512 MB PC-2100 Samsung RAM
Maxtor 40 GB 7200 RPMS
MSI Geforce 4 Ti 4400
SB Live Value!
Windows XP Professional
M.N.
My SPECS:
Athlon 1900+ XP
Epox 8KHA+
SB Live Value!
M.N.
