Please Help! Audigy 1 Platinum Problems!
jhbball
Hi everyone, just got a new audigy platinum installed, and i'm having difficulty with it.
I'm using creative 5300 Analog 5.1 speakers with it, but i can't seem to get the center channel working in games, movies, music and such. In the speaker test, it tests fine. But no dice in the other areas! Please help me out 🙂
Thanks
the original jhbball
hmm u sure..?....and u sure u plugged in the connections of ur speaker correctly?...like how one of 'em should go into the digital out....(made my center work)..
and fyi...dl the latest drivers cuz the ones that came from CD has a lot of bugs....so crazy of a bug that it made me reformat my winxp...suxors...aha.oh wells....
hope the connection solution thing helps!..oh and read the manual that came w/ ur speakers carefully..... 🙂
Yes, i think they're all in the right ports. The center channel is plugged into the port farthest away from the firewire. So i think i'm set there. meh, any other ideas?
u sure in ALL those movies and games it doesn't work?...maybe it's just a couple of 'em and u just didn't set it to run @ 5.1 in each software's program?.....chk again @ ur speakers' user manual....and make sure all all the connections are where it's suppose to be @.....just chk again..hehhe
