please help and tell me diferences between two monitors
nomagic
143
They both use 24-inch TFT TN panels, so they are only differentiated by appearance, features, and stand design.
The T240 stand has "swivel and tilt" design, while the other has "tilt" design.
The T240 supports HDMI connector, while the other doesn?t.
May I softly suggest that next time you do some homework before you ask questions?
MrSnuffy
No u cant, because u didt tell me anything new. I know that both are 24 inch TN panels, one without HDMI etc. I wanted to know differences that i cant read from normal web pages and stats, like wich piece uses better panel ---> basically wich one has better colors and is nicer/faster/superior screen.
Jessica69
501
Dude, if they both use a 24" TN panel, I highly doubt you'd notice a heck of a lot of difference, esp. considering they're from the same manufacturer. Think it'd come down to color accuracy, input lag, features you want, etc.
