Hello all. Let me start by saying that I love this forum because I feel like people give honest answers. At other places, I think people boast about outrageous OC'ing that just doesn't seem possible.
Anyway... Here is the deal. I have the setup seen in my profile below (also, I'm using Arctic Silver II). I am using Motherboard monitor 5 which correlates highly with what the bios tells me. The MBM stats say I'm running:
41C, 30C and 23C (I don't know where it is getting these temperatures; I assume there are 3 temperature diodes on the MB). Under load, the 41C may get up to 44 or 45C. From what I've read in other posts, I guess ~40C is normal for an OC'd system. However, here are my problems and questions...
Problem: Before I OC'd I consistently ran at ~30C. So just this 52Mhz OC is making the temp rise 10C? It doesn't seem worth it.
Problem: MBM reports that Core 0 is running at 1.84 Volts (unfortunately I don't know what the voltage was before I OC'd it). The default for this chip is 1.7 V. I tried setting the voltage to a lower amount in the BIOS, but it doesn't seem to matter. No matter what I set the bios at, MBM reports the same voltage for Core 0 (1.84 V). Suggestions about this?
Question: I currently have the jumper on the MB set to 100Mhz FSB, and when posting, the BIOS says "DRAM CLK 100 Mhz" even though I have the OC'd setting to 112Mhz for the FSB. I assume the BIOS starts out at 100Mhz, but then switches to 112Mhz after posting? Should I set the jumper to 133Mhz? I also read that you can just remove this jumper completely and the system will still work normally. Comments about this?
Question: I'm running 133Mhz RAM (a Micron chipset and a Kingston ValueRam chipset, both CAS 3, although I'm running them at CAS 2) but I could only get them to run stable at 7.5 x 122 = 915Mhz. I eventually went with an OC of 8.5 x 112 = 952Mhz which runs stable. Obviously I have tons of options to OC, and I don't really know what the best way to go is... Should I go with the highest FSB my RAM will support and lower the multiplier? Or should I have a higher multiplier setting and a modest increase in FSB? Another way to ask this question is; if I have a faster FSB setting, but lower overall calculated system speed (e.g. 7.5 x 122 = 915Mhz) will that be faster than a lower FSB setting with a faster overall speed (e.g. 8.5 x 112 = 952Mhz)? I suppose I could run Sis Sandra, but I don't happen to have it.
I appreciate any comments - especially regarding the voltage issue. I think if I could just lower the voltage the chip would still OC but the temp would decrease.
