hello
i am having a few problems with my new a8v and 3500+ with corsair 512 x 2 twinxl pro RAM. i was hoping a few of you techies could help me.
the system is new so i am running everything stock - no OC or anything. when the machine boots, it's fast! however i have a problem. any time i turn the machine off, it forgets that the VIA sata controller is even there.
this means that when i boot, i get "hardware initiate failed" and no windows, because my system is on the 160GB sata drive.
then i have to reboot, go into the BIOS (v1006), set the main drive to be the one on the VIA sata controller (which has windows installed), set THAT drive to be the 2nd boot device (since the order of that also goes away when it forgets the drive is there), then continue to boot.
This happens every time I turn the computer off. all other BIOS settings are being retained - so i don't think it is a battery issue. this isn't a huge problem, but it is MAJORLY annoying.
does anyone else have this problem or know what I can do to fix it?
thanks
jeff
thanks
jeff
