I just built the following system
Gigabyte 7VRXP Rev 1.1
Athlon XP 1900+
Generic PC2700 512mb
Maxtor D740X-6L (60gb ATA133 7200rpm)
Gainward Ultra 650/XP (GeForce4 Ti4200 128mb)
Antex SX1030 (with 300w P/S)
Using onboard LAN and old SB Live 5.1 OEM
First issue: I bought an extra case fan (Sunon 80mm) for the front, the SX1030 comes with an optional spot, but I can't find any place to plug the fan in on the 7VRXP. Am I just blind? Is there such a thing as an adapter that converts the IDE power to 80mm fan power?
Second issue: Feature, or set up improperly? The power button doesn't shut the system down properly, nor will XP shutdown the system. What happens is when I flick the switch at the back of the case, all the fans fire up, but I get no video and so forth, I hit the power button and everything comes on, the system fires up and runs properly, when I go to shut down XP the screen hangs at 'Windows is shutting down'. Hitting the power button will sometimes act like a reset button, and sometimes shut the system down, but in the latter case the fans and fan on the power unit still run until I flick off the switch at the back of the case. Is this a feature or do I have something plugged in wrong?
Third issue: I'm getting 30 fps in Dungeon Siege in very calm and low poly situations, sometimes worse. Isn't that excessively low for my system?!
Many thanks to those who respond
Athlon XP 1900+
