Please Explain Monitor Hz to me
Murphq
102
I have no clue on this, and I bet its really simple too.
How can you tell whats optimal for your monitor? Does it have anyhting to do with your vid card? Is a higher Hz better?
Regs
16,666
21
Hertz is a measurement of your monitors refresh rate. Mostly affecting CRT monitors, the higher the refresh rate at a higher resolution, the better. Mine runs 85 Hertz @ suggested resolution of 1024 x 768. Other and more expensive monitors can run over 1152 x 864 resolution with a 85 Hz refresh rate, while mine can only run @ 60 Hz's at 1152 x 864.
Refresh rate is pretty much how many times the display on your screen is re drawn or renewed in a second. Since most graphic cards of both yesterday and today can support all main stream resolutions and refresh rates, it's up to your monitor to push out those Hertz's.
You would have to search the web or the manufactures web site to find out your monitors suggested settings.
dullard
26,047
4,692
Monitor Hz is how fequently a picture is drawn on the monitor. People can only see a given number of images in a second.
Monitors show brief points of light that quickly fade to black. This happens repeatedly - so fast that your mind blurs the light and ignores the black. If a monitor displayed at 1 Hz, you would actually see a picture for a fraction of a second and black for the rest of the second. Basically it would look like it was turning on and off at a frequency of 1 Hz.
If that 1 Hz monitor was set to 2 Hz, you'd see two images each second and black in between. Imagine that frequency is slowly turned higher and higher. People's eyes/brain have a limit to how fast it can see images. Eventually your eyes/mind will blur the light together and ignore the black - forming an image that APPEARS to be on all the time.
The exact frequency where your eyes/mind can no longer see the black varies from person to person. For example: Flourescent lights turn on and off at 60 Hz (in America, it is less in some other regions), and some people can actually see it turn on/off in a flicker that gives them migranes - while most other people look at a flourescent light and see constant light.
Obviously if your monitor is at 60 Hz and you get headaches from a flourescent light, then you will also get headaches from a monitor flickering on/off at 60 Hz. For other people it makes no difference. That is the reason that monitors have adjustable refresh rates - since different people are different. If it bothers your eyes, turn it up a bit.
Note: going too high can cause another problem. Any multiple of your limit will also cause problems. So if you have problems at 60 Hz, you'd also have problems at 120 Hz. So I don't argue to always set it as high as possible - instead set it as high as is needed to avoid eye problems and headaches.
Wiktor
151
In short:
-Optimal is 85Hz (100Hz doesn't hurt and you might see the difference)
-75 is a good minimum for no flickering.
-60 is as low as you should go (CRTs don't go lower than that anyway)
-it is pointless to set extreme refresh rates for the lowest resolutions (like 144Hz or higher), but it will not damage the monitor if you do.
All modern video cards support reasonably higher refresh rates than any standard CRT can display at a given resolution.
bjc112
11,460
Wow, i did not know that part...
You learn something everyday. Thanks D.
beatle
5,661
Why is that? I'd never heard that before.
Ionizer86
5,292
I just noticed something odd: in my Cat 3.8 drivers, if I uncheck the "hide modes that monitor cannot display," I can up it to over 85Hz (what I thought was the limit) at 1024 (17" CRT). Is it really running at 100 or 120 now? How can I tell?
Budman
This is the reason right there why Dullard is Elite. ;)
