junglerecker
Hi!!
I posted a potential system in this forum last week and got some awesome feedback. Since then I've updated many of my components per all of your recommendations (except the power supply which I REALLY WANT to keep in there).
These are my plans for final purchases. Does anyone see anything (besides the PSU which I KNOW is overkill, but I'm getting it anyway 😉 ) that could/ should be changed??
Thanks so much!! I've put posts up in a number of computer forums and the feedback I got here surpassed most of the others combined! I'm really really grateful.
James
ASUS P5B Deluxe/WiFi-AP Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard
http://www.newegg.com/Product/Produc...82E16813131028
Intel Core 2 Duo E6600 Conroe 2.4GHz 4M sharing L2 Cache LGA 775 Processor
http://www.newegg.com/Product/Produc...82E16819115003
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 675 (PC2 5400) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Produc...82E16820145015
XFX PVT71PUDF3 Geforce 7900GS 256MB 256-bit GDDR3 PCI Express x16 Video Card
http://www.newegg.com/Product/Produc...82E16814150184
NEC Black 16X DVD+R 8X DVD+RW 8X DVD+R DL 16X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2M Cache IDE/ATAPI DVD Burner
http://www.newegg.com/Product/Produc...82E16827152058
LG Black 16X DVD+R 8X DVD+RW 10X DVD+R DL 16X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2M Cache E-IDE/ATAPI Super-Multi DVD Burner
http://www.newegg.com/Product/Produc...82E16827136091
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Produc...82E16822148140
PC Power & Cooling 510 SLI-PFC ATX12V 510W Continuous @ 50°C Power Supply 90 - 264V UL/ ULC/ TUV/ CE
http://www.newegg.com/Product/Produc...82E16817703001
Antec Performance I P180 Silver 0.8mm ATX Mid Tower Computer Case
http://www.newegg.com/Product/Produc...82E16811129154
Antec 77095 120mm Blue LED Light Case Cooling Fan
http://www.newegg.com/Product/Produc...82E16835129016
EVERCOOL EC8015 80mm Ball Case Cooling Fan
http://www.newegg.com/Product/Produc...82E16835119041
SAMSUNG 204B-BK Black 20.1" 5ms LCD Monitor 300 cd/m2 800:1 0.255mm Pixel Pitch 1600x1200 display
Logitech Cordless Desktop S 510 967557 Keyboard + Mouse
(the last two I'm buying from Bestbuy)
James
