- Jun 11, 2011
- 859
- 4
- 76
Hello, it's me again and I'm in need of your valuable advice again!
I have spent 50+ hours building a perfect PC with a strict budget of 750$ in Lithuania. I would really appreciate if you could comment on it.
Here's my cart of the shop I'm going to buy all the parts from (except the gpu):
http://www.skytech.lt/krepselis-31423.html
I would like to comment, that I tried to build a quality build. I didn't want to take the cheapest case, motherboard, psu, etc.
I took 800W corsair PSU intently for future upgrades and because I think the PC will be of lower temp and noise if PSU will work only at 50% of its power.
I took the best i3 processor because i5 cost too much for me, plus, I don't like multitasking and the best i3 is simply absolutely enough for all games.
Now you may be wondering where the GPU is! I bought it separately and it is "ASUS GTX 560 Ti DirectCU II" (stock overclocked).
I would greatly appreciate comments and criticism on the build overall, but I would also like to ask if the motherboard, PSU and GPU are all compatible? Will all connections fit?
Here it shows the connections to this card:
http://www.asus.com/websites/global/products/dmCuxCxRSaUPVbYQ/ioports.jpg
I'm not sure what each of them means, but it appears that there are two DVIs
However, them motherboard of my choice only has one DVI?
http://www.skytech.lt/h61-s1155-matxh61mue35-msi-p-60578.html
Perhaps I simply misunderstand something? I have very little practical hardware knowledge, because I own a very old Dell computer and I don't touch it at all.
