Please check system parts and help me make changes
seymourman
22
I didnt put in the links, I figure most of you know exactly what these are. Looking for some ways to save some money without really hurting performance. I am not an overclocker.
This system will be a typical Home computer. I have a 17y/o son who games but doesnt play a lot of FPS. I wanto order Thursday.
1. Lian Li 7b black aluminum case.
a. Is there a better case for less?
b. I have considered CoolerMaster Centurion or Cavalier.
2 Fortron 550W Dual rail or Sparkle 550W single rail.
a. Dual or Single Rail?
b. Do I need this much power? Is 400-450W enough?
3. AMD 3700+ San Diego CPU.
4. Corsair Value Ram 2x1gb. Ram is cheap but maybe I dont need this much.
5 Seagate 250gb HD Sata (I might add second HD later).
a. Is this to big? Would a 120GB or so be better and add a second one?
6. NEC 3550 DVD burner.
7. EVGA 7800GT (516 model) video card.
a. Really thought about 6800GS at first since i will upgrade this in less than a
year. If the 7800GT was way over $300 probably go with 6800gs but at
$299 for the 7800GT it is too tempting.
8. Sound card??? I am only using a 2.1 system so I dont want to spend a lot.
a. Do I even need one?
b. Is the Soundblaster Live 24 bit good enough or do I need an Audigy?
Now what I am really struggling with is picking a Motherboard. I am looking for a rock solid stable, good parts on board, excellent build quality. I would like firewire, but I do have a firewire card I could use. I have thought about the ASUS A8N-E, Epox Ultra, even the new Asus A8R-MVP. I dont plan to SLI, but if i need to get an SLI board to get the build quality I will.
So if you folks would check my list for any change suggestions and help me pick a Motherboard I will greatly appreciate it.
Meuge
Banned
Nov 27, 2005
2,963
Eh... Drop the SD and get an X2 3800. Unless you're going to go DC, there is no sense gettiing anything above a venice 3200.
Don't worry about the sound card. If you get an EPoX 9NPA+ Ultra, you get pretty decent sound, with digital in/out.
I like Samsung hard drives for the fact that they're cheap and quiet.
Consider the Antec P180 for the case.
seymourman
22
So you would recommend the EPoX 9NPA+ Ultra board for my need?
Can I get by with a slightly less power supply. I still want a quality unit but if it will
save some cash I might consider it.
Meuge
Banned
Nov 27, 2005
2,963
Yes, I'd recommend the Epox. As far as power goes, an Antec TruePower 2.0 dual-rail one... 500W is a bit under $100.
seymourman
22
The X2 3800 is out of my budget for now. I have thought about a 3200 venice now and then swap out to a Dual Core next year when they drop in price. But I wasnt sure why kind of a performance drop I would get.
Thanks for the Epox recommendation.
Mogadon
739
Seasonic make great PSU's. This 430W will do you fine, although if you feel like you need/want a little more this 500W is great, though a little more expensive.
Antec TPII's are good as well though ... ;)
I think those two PSU's will have issues with cable length in the P180 case, check out the Lian-Li case too, they're pretty neat.
fire400
5,204
21
i would go for a seasonic, that way you don't have to listen to your whining PSU
if you're not going to be running that much, I doubt you would notice the difference between 1gig vs 2gigs of ram. you could find a 7800 card for 350 bucks.
