Please check my parts list.
Discussion in 'General Hardware' started by charlietee, Nov 19, 2012.
  1. charlietee
    charlietee Golden Member
    Jul 27, 2001
    1,218
    Trying to build a box for a friend who has started videoing the live shows. She was going to wait until Q2 2013 for the build but MicroCenter has the Intel Core i7 3770K for $229.00.
    My last build for her is 5 years old and is not really up to rendering video. I am going to use the Cooler Master case. Corsair 550 watt power supply, WD Black 640gig hard drive.
    Will be adding 2 more hard drives for strach disk.
    It will also be used for general office work and gaming. Not looking to build a "rendering only" box.
    Upgrade parts.
    Intel Core i7 3770k Processor $250 out the door.
    http://www.microcenter.com/product/388575/Core_i7_3770K_35GHz_LGA_1155_Processor#
    ASUS P8Z77-V PRO Motherboard $210 out the door.
    http://www.newegg.com/Product/Produc...82E16813131819
    EVGA 025-P3-1579-AR GeForce GTX 570 (Fermi) HD 2560MB 320-bit GDDR5 $320.00 out the door.
    http://www.newegg.com/Product/Produc...82E16814130687
    G.SKILL F3-1600C9Q-32GXM 32gig Dual Channel Memory $110 out the door.
    http://www.newegg.com/Product/Produc...82E16820231569
    I have busted the budget by about $150.00 but feel the 32gigs of RAM is a must have. I could save a few dollars using the ASRock Z77 Extreme6 motherboard but have no experience with them and like Asus in a "office/commercial" setting.
    http://www.newegg.com/Product/Produc...82E16813157295
    I want to use a EVGA video card because of the lifetime warranty. Office guy has a tuff job. Plays Star Wars The Old Republic 10-12 hours a day and a couple of other games. I do not know which ones.
    The video card seems to be my biggest delima. Cuda Cores, 320bit or 256bit bus, 2gigs of RAM or just 1gig, Open GL 4.1 or 4.2 support ??? Ivy Bridge performance boost with pci 3.0x16 even with a nVidia 570 series to take advantage of even 2.0x16 ???
    On the video card there are several other options from EVGA
    http://www.newegg.com/Product/Produc...130%2D620%2DTS
    Really been out of the loop for a couple of years and do not want to make a bad hardware choice given the limited budget.
    The processor is a done deal and I will probably order the ram while NewEgg has it instock and with the IronEgg pricing.
    Really like the AsRock board but am afraid a couple years down the road it will give me problems. Used Abit boards for a long time and hung on till the very last end with several failures and then new boards that were DOA.
    Not good in a business enviorment.
    Any help, suggestions, feedback would be greatly appreciated.
  2. Loading...
    Similar Threads - check parts list Forum Date
    Part check, motherboard recommendations and other tweaks for ~$1000 gaming rig? General Hardware Feb 9, 2014
    Anyone feel like checking my parts list? Mid-high end gaming. General Hardware Feb 6, 2014
    Check Custom Build + Part Advice (future proof, cost efficient gaming rig) General Hardware Sep 16, 2013
    Computer Part list check General Hardware Jun 7, 2006
    can somebody check my parts list please? General Hardware Feb 25, 2006
  3. T_Yamamoto
    T_Yamamoto Lifer
    Jul 6, 2011
    13,860
    9
    Asrock is a spinoff of ASUS but better (IMHO) and Newegg reviews dont really mean anything since most of the people reviewing are people with problems and/or DOAs
    No need for a 210 dollar motherboard when this will work perfectly fine
    Also, drop down to 16gbs and add an ssd
  4. WiseUp216
    WiseUp216 Platinum Member
    Mar 12, 2012
    2,138
    11
    I certainly wouldn't pay $320.00 for a GTX 570 these days. A lot of better and/or cheaper options available.
  5. VirtualLarry
    VirtualLarry Lifer
    Aug 25, 2001
    35,776
    604
    If you do go with 32GB of RAM, be aware that Windows 7 Home Premium 64-bit only supports 16GB max, so you would have to go with Pro. I don't know about Windows 8.
  6. charlietee
    Jul 27, 2001
    1,218
    Well NewEgg does have the AsRock Extreme4 for $105.00 shipped. Rave reviews and it is $100.00 cheaper than the Asus
    http://www.newegg.com/Product/Produc...82E16813157293
    So in your opinion the AsRock build quality is on par or better than Asus ???
  7. charlietee
    Jul 27, 2001
    1,218
    The nVidia GTX 570 is listed with Adobe Systems as a video card that will use Cuda and the GPU to actually render video. I too agree that $320.00 is a bit much for a GTX 570. But it falls right into the most important function this box will be asked to do. Playing games is not really a concern of mine. Being able to render video is the most cpu, ram, drive system and in the case of the nVidia GTX 570 intensive task it will perform.
    So any suggestion on a nVidia card that has 2gigs of ram, cuda and at least a 256bit bus would be greatly appreciated.
  8. mfenn
    mfenn Elite Member <br> Currently on <BR> Moderator Sabb
    Jan 17, 2010
    22,403
    I see no reason to be spending $200 or even $100 on motherboard for this machine. There's just no point in getting a "tweaker" motherboard for a machine that will be used for real work.
    i7 3770K $230 @ MC
    ASRock Z77 Pro3 $55 @ MC (combo with CPU)
    Crucial DDR3 1600 32GB $148 - not sure where you got the $110 price from
    MSI GTX 570 $230 AR - 1.25GB VRAM is enough for MPE unless you're shooting 4K
    Total: $663 AR
    $75 under budget and just as fast.
  9. T_Yamamoto
    T_Yamamoto Lifer
    Jul 6, 2011
    13,860
    9
    Yup, AsRock>ASUS
