Please check my first build!
Kashin
CPU : Intel Core i7-4770K (€314 - Alternate)
GPU : Asus GTX780 DC2 3 GB (€629 - Alternate)
RAM : G.Skill ARES 16 GB DDR3-1866 Kit (2x8GB) (€124,90 - Alternate)
MOBO : ASUS Z87-PRO (€182,90 - Alternate)
CASE : Cooler Master HAF X (€149,90 - Alternate)
SSD : Samsung 840 EVO 250GB (€152,90 - Alternate)
HDD : Seagate Barracuda 2TB (€78,90 - Alternate)
PSU : Corsair CX750M (€84,90 - Alternate)
CPU Cooler : Thermalright Silver Arrow SB-E (€69,90 - Alternate)
DVD R/W : LG GH24NS70 (€16,99 - Alternate)
Total: €1804,29
It will be used for music editing / production, as well as gaming and heavy duty modding / emulation.
Need some more info than that.
http://forums.anandtech.com/showthread.php?t=80121
Filled some in for you:
1. What YOUR PC will be used for.
2. What YOUR budget is. A 20% price range is acceptable
3. What country YOU will be buying YOUR parts from.
the Netherlands
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
www.alternate.nl ; do you accept other shops?
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
monitor, keyboard, mouse?
7. IF YOU plan on overclocking or run the system at default speeds.
??? if yes, how much?
8. What resolution, not monitor size, will you be using?
9. WHEN do you plan to build it?
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
