Pleaes help solve this hardcore MATH problem!! HARD!!
gwlam12
The integral from 0 to 2pi of (cos(2x))/(5+4cosx) ...make sure you remmeer to change the x's to z's and that cos (2x) = 2(cos 2(x))^2 - 1. and remeber that cos z = (z^-1+z)/2. Use residues
TI-89 🙂
Actually though, I think this may (or may not) be a case for partial fractions. I can't remeber if partial fractions fit though.
Which calc class are you in?
To start multiply by the inverse of (5+4cosx) over the inverse of (5+4cosx) so that your multipling by one. That will get ride of your nasty denominator.
I'm guessing you mean the conjugate, and not the inverse? Anyway, neither works here, since trigonometric functions are not square roots. 😉
WTF are residues? I figured it out and had no problems doing it. Easy problem.
cos 2x = cos<SUP>2</SUP> x ? sin<SUP>2</SUP> x = 2 cos<SUP>2</SUP> x ? 1 = 1 ? 2 sin<SUP>2</SUP> x
This makes it stupidly easy.
Residues are something you would learn in complex variable calculus...and therefore, since he is supposed to solve the problem using the Residue Theorem, the problem isn't stupidly easy now is it.
So don't be such a retard next time.
did you notice that cos in the denominator? Please, try your method and if it works I'd like to hear it.
I'd like to know, too.
according to math league and all my advanced mathematics course notes....
the answer is either 0,1,-1, infinity, negative infinity, or undefined.
pick one.
