The problem is that his setup is high end, but it's very aged. I texted him and he said that he sold off his old receivers. He still has a Separate Pre-Amp and Amp, but they're so old they don't support HDMI. Thus, I was hoping he could lean on the PS3, so I need to know those audio specifications.
It still does digital audio out over optical, though, correct?
Yes, the PS3 has optical out capability.
Problem, however, is that over optical, you won't be able to do the advanced audio codecs, iirc.
I always mix up the details since I rarely dig up the relevant information anymore, but I also know the PS3 has limited compatibility with the advanced audio codecs (lossless, like DD TrueHD and DTS-MA), and can only decode internal and pass on uncompressed PCM, as opposed to bitstream output of the codecs for the receiver to decode.
Off the top of my head, I cannot recall if Optical can handle the amount of data present in a 6 channel uncompressed PCM output. Also not sure if optical can even handle the advanced codecs, assuming a receiver can.
Now that I recall, I'm pretty sure the PS3 has zero problems internally decoding and passing on (as uncompressed multichannel PCM) Dolby TrueHD and DTS-MA. The only problem with the receiver only getting PCM though, is you typically lose advanced capabilities on the receiver. No choosing of various Dolby processing styles, might lose any internal EQ abilities, including night-time range compression and similar "sensitive" volume management parameters. You may retain all of those, I cannot recall, never really messed with them much. I may have learned you couldn't, as I was forced to make the PS3 decode on my last receiver.
If the receiver is so old that digital connections are minimum, I hate to say it, it's sort of time to upgrade if wishing to partake in the latest audio and video quality revolutions. Being able to handle multiple HDMI connections, decode every single possible audio codec (and TrueHD and DTS-MA are basically the only thing on Blu-ray these days - though you always have access to the standard "lossy core" of basic Dolby Digital or DTS), as well as handle every frequency and framerate combination for HD formats.
Then again, I'll admit, I refuse to be left behind and absolutely demand the latest and greatest features, to a reasonable extent.
I mostly upgraded my receiver to be able to handle 3D, but it also had the benefit of adding four 4 HDMI inputs to the 2 to which I was previously limited (though one of the six is slightly useless, being located in the front). And of course, it's fully compatible with everything in the HDMI v1.4 spec and all the audio and video formats in use today.
Unless one wants to invest in a way that plans for upgrading to 4K, buying now offers a good chance to have a capable receiver for probably another decade - especially if there is an acceptance of paying a little more now, since there is available 4K support. Might need to wait a little while for an AVR upgrade, however, if one really wants to be totally ready for 4K-3D and everything else.
Can HDMI v1.4 handle 4K 3D? I doubt there is much in the way of 4K-3D content, and not even sure of the 3D capability of the current 4K sets. I have a feeling 4K 3D isn't standardized yet. Heck, can't really even say 4K is standardized yet. :\ There seems to be a few resolutions that fall under the 4K banner, though maybe I haven't been paying enough attention in the past year to 4K. I've seen a few absurdly priced sets, but I know I'm not ready for one. I can't afford the size that would allow, based on where I sit, to actually discern the difference in detail between HD and UltraHD. And then there's the total lack of content today. I'll wait for maturity of the UltraHD market and content market before I even think of jumping.
