Originally posted by: Kaido
Originally posted by: TheStu
I sort of agree with the USB port issue, but at the same time, what do you need to plug in there? If you are at a desk, you will probably have a hub anyway so that way you can have your printer, external devices, ipods, and what not hooked up there, stuff that isnt easy to take with you. But when you are on the road, you already have wifi, bluetooth, and a decent sound chip. So the need to hook up extra things is minimized since you are going portable.
Conversely, it gets annoying on my machine to have to unplug my thumbdrive or mouse if I want to use my external USB hard drive (it requires 2 ports)
I use a lot more devices than the typical person too. I love my 14" Gateway laptop because it has 4 USB ports, which is typically just what I need. My bag usually has the following USB devices:
-wireless mouse
-memory stick
-card reader
-portable hard drive or two
-card reader hard drive
-wacom tablet
-sometimes a portable printer
-iPod
It's a small pain to swap things out and can get even more messy when you toss a USB hub into the ring. You'd just figure that for $2,500 you'd get a bit more for your money than a screen that can't go back all the way and only 2 USB ports, you know?
