How do you tell which section of the platter the OS will be installed to when using multiple partitions on a HDD?... or even a single partition HDD for that matter.
You don't and it's not something you should be worrying about anyway.
Originally posted by: oscar6
Originally posted by: Billb2
The boot sector, MBR and boot files go onto the first sector of the first HDD Windows Install sees...the one set a boot disk in the BIOS when doing the install. The Windows program files (the Windows folder, if you will) can go anywhere you want.
Then why do so many people here repeat that you should place the OS on the outside platter for best performance? :roll:
Also I quoted the wrong person with the second post.
So really there is little point. I'm guessing it has been often mentioned due to a bandwagon effect. It feels good to somewhat understand the commonly misunderstood.
The large majority are pointless or affect things other than what people say they will but they keep doing them none the less.
Write performance:
As we've seen earlier, random writes are the SSD's achilles heel because of it's erase blocks, so performance is not nearly as good as the random reads. Disk drives on the other hand are able to cache written blocks and write them later. The partitioning trick helped with random writes as well, improving the score of the 32 GB Raptor partition by 20% and the score of the Velociraptor partition by 30% compared to the full disk.
The end result is that while the SSD is 11% faster than the 32 GB Raptor partition, the Velociraptor partition beats the SSD by 6% ? however without partitioning the SSD is 13% faster than the Velociraptor (and 43% faster than the Raptor).
Originally posted by: Yellowbeard
A lot of these tweak guides and the advice to use speed tweaks date back several years to the front end of XP. With every facet of system performance exponentially better these days, most of the tweaks probably do not have as much effect. But, back in the day gaining a few percentage points of performance here and there was nice. And, if you do lots of small tweaks, they do have a cumulative effect.
If HD I/O is truly an issue for the OP, go RAID-0 or 0+1 if you need redundancy.
If you're referring to my post, the article was posted on 6/16/2008, and I consider a 30% increase a tad more than a tweek.![]()
