Plastic clamshell cases for MS Pro Duo media.
bonheur
Hey guys,
I would like you to see the following plastic clamshell cases that I use for keeping my MS Pro Duo memory cards safe.
As you can see there's two different kinds of clamshell cases on the pictures above that I have named "A" and "B".
I like the "A" type as they're very slim and they hold the Pro Duo memory card tight so it doesn't move around in transport. On the downside, those cases may be difficult to open when you have numb fingers and so goes for removing the memory card from the pegs that hold it tight.
The "B" type of clamshell cases is of a lower quality as in the case doesn't have a tight fit and the MS Pro Duo card can move a little bit in transport--which makes some noise. I also have some doubts about their longevity. These cases are huge compared to type "A" cases. On the good side, the card is easy to pick up when you have numb fingers--as in a cold day-- and those cases are really easy to pop up open.
The "B" type of plastic clamshell cases can be found on several websites in the likes of eBay and several online Chinese stores. But I have not been able to source type "A" plastic clamshell cases anywhere. The only type "A" clamshell case that I have came with a SanDisk MS Pro Duo memory card made in the year 2007 [back when they still labeled their cards "2.0 GB"--notice the "point zero"].
Thus, do you know where I could buy some type "A" cases online? Or if you have got some of those type "A" cases and you're willing to give them away just drop me a private message.
Thank you in advance for all of your comments!
Update:
A SanDisk representative just told me that they don't stock "type A" plastic clamshell cases anymore and they don't know of any similar product in the market either.
