Plasma screen power cable options, Please Help.
Derrthomp
Hello,
I recently bought a hitachi 42" plasma screen. However it did not come with a power cable, the person whom i bought it from had previously lost it. Can i use a computer power cable safely in place of the one that came with the tv?
Harvey
Administrator<br>Elite Member
73
Your TV and computer both use AC cords with a standard IEC C13 connector. The only question is whether the actual wire is of sufficient guage to handle the current required by your plasma TV.
Somewhere in the manual and on the back of your TV, you should find the current consumption spec, usually in amps (A). 42" plasma TV's listed on this page, consume from 146.49 to 235.32 watts. As a close approximation, AC volts x current = power (watts) so 120 V x 2 A = 240 W so a cable rated for 2.5 A (~300 W) or more should be safe.
sdifox
100,554
17,978
just go to your IT department and ask them for a spare server power cable. They are usually long and heavy gauge.
