Plasma is actually a little better for gaming than LCD. Plasma uses a similar method to CRT's, where phosphors are lit up to provide the image, so the pixels have instant on/off time which means no motion blur. This makes moving text easier to read and makes it easier to focus while moving.
Thats weird. I've often heard the LCD is better for gaming than plasma. I suppose there is a definitive answer. Bound to be some professional reviews doing a comparison somewhere on the net. We cant be the first to talk about it or question it.
I think the original reasoning for that point of view was because LCD's were much less susceptible to burn in, but now plasmas pixel shift the image to prevent it from burning in.
Having owned a 1080i Plasma 42" for 1 year and a 1080p LCD 47" for 2 years and gamed heavily on both sets, I would agree that the Plasma is better but not for the reason you mentioned.
Plasma's have much better IQ for games in my opinion. If you had an LCD and never saw a Plasma in action for a sustained period of time, you would not be disappointed. I regret buying LCD over Plasma for my second set on IQ alone.
LCD's are much more friendly on the heat issue though which I appreciate being in a small room.
I went ahead and ran this test that demonstrates motion blur/ghosting:
http://www.prad.de/en/monitore/testsoftware/pixperan.html
The program has a lot of tests that will demonstrate the issues of LCD but the one most quantifiable is the simple readability test. It scrolls a set of random letters across the screen at increasing speed to see how long you can make out the letters. The slow response times of LCD quickly shows how motion blur/ghosting makes images lose clarity while moving. The higher tempo you can read at the less ghosting is occuring.
My results:
Asus 2ms LCD - 8
Dell 5ms LCD - 7
Netbook - 6
Plasma - 23
On my best LCD display I was only able to read at a tempo of 8, on a plasma I was able to read a tempo of 23, after which point it was simply too fast to follow the letters. I couldn't run at native resolution because my netbook doesn't have HDMI and I think if I was at native I could've gotten several steps higher. I haven't tested an LCD TV yet but I wager it will be about equal to the netbook in the motion blur department because response time isn't a selling point for HDTV's.
I play a lot of MMO's and one of the things that always bugs me is not being able to read mob names when running around. I also notice in FPS games I have to stop the camera for a split second to really refocus on things. Both those are ghosting issues. I actually wish I could get a 23" plasma display for PC use 🙂
Interesting program, thanks for the mention. I ran it on my Dell LCD and only got to 6. 🙁
One caveat, and I very much prefer Plasma--is that they are susceptible to Image retention. I assume it is much much better than my current 4 year-old panel, but it's very noticeable in mine, particularly with games--going from super bright colors to dark-high contrast areas.
image retention is not the same as burn-in. Burn-in is permanent, IR is simply the ghost or halo of an image retained on the panel when switching to another image. It tends to go away quickly. For this reason, I recall LCD generally being the preferred panel for games.
and the glare thing is true too. You really need a dark room to get everything out of a plasma.
burn-in was a legitimate concern for using plasmas as a standard use computer monitor where you have a lot of static images (of which you'd then have a legitimate use for a screen saver 😛), but for gaming which is mostly moving images its always been considered excellent
Unless you're playing a game like Demon's Souls with a static HUD. You'll get some serious IR in no time, and have to do some screen wiping to get it to reset.
I have a Samsung pn42a450 from a few years back. It's definitely not high end. I get image retention from HUDs, it's not noticeable unless I'm looking for it though.
^ that says "Input incorrect!"
don't know why they decided to make it green and not red.
Damnit I beat the game, wouldn't go past level 26.
Using Samsung PN58C7000 in game mode, currently playing Dead Space 2 and TDU2.
Image retention is almost nonexistent on this tv after doing the break-in. I've played hundreds of hours of games and seen very light IR only after playing the same game day after day for 2+ hours at a time. Couple minutes of the scrolling screen and it's gone.
Highly recommend plasma for gaming and movies as long as you don't watch in a bright room.
