I'm waiting for Ivy Bridge E parts but I'm trying to start planning my next machine build.
I want the fastest machine I can build that is 1) as close to silent as possible and 2) won't be overclocked.
I've already decided on the Nanoxia DS1 for the case and I'll probably get the 2nd fastest IB-E processor.
Total budget will be about $2500.
For the quietest build, what's better - air or water? I can figure out the best to get in either case based on reviews on the main site. I just don't ever see them compared for noise on a non overclocked system.
Related question, I have Gelid fans in my current system and they are great - but they're also $25/fan. I imagine I will end up with 4 to 6 fans in the case so that becomes a significant cost. Is there an alternative that is close to the quietness of the Gelid with the amount of air they move at a lower cost?
Thanks in advance.
Thanks in advance.
