Hi all,
I'm looking to build a small, moderately powered desktop soon with a few goals:
1. Keep the form factor as small as possible (details below)
2. Keep the cost as low as possible
The machine would be mostly used for basic web browsing and excel, but it would occasionally need some oomph for compiling code and photo editing. I don't plan on doing too much gaming, but I'd like to hold out for a nice integrated graphics solution (intel hd 5000+) so I'll have power available when I need it.
Right now I'm trying to decide between mini-ITX and mATX, with cost being the main factor.
I'd ideally like mini-ITX, but it seems to drive up the price of the motherboard.
What cases would you look at that meet this criteria?
1. As small as possible, but also:
2. Can accommodate a regular sized PSU. My thought is that the small form factor psu's might not provide enough power for an i5-4xxx cpu
3. Isn't noisy (I don't want to drop down to 40mm-60mm fans if I can avoid it)
4. Has to fit at least (1) 2.5" drive/SSD, and (1) 3.5" drive/HD
5. I'm torn on optical drives. Obviously smaller cases will have no optical drive or a slim drive, but slim drives are also more expensive. ($100 vs $20). With that said, I'm leaning towards no optical drive at all, or a case just big enough to fit a standard drive.
Question 1:
Any suggestions on cases? Am I better off just going with the smallest mATX case possible? That would probably make my motherboard choices more flexible/cheaper and allow for a standard PSU, but it's probably not quite as sexy.
Question 2:
Thoughts on using the small form factor PSU's? Can these really handle the haswell i5's?
Question 1:
Question 2:
