Planning a Danger Den WC system...
Kitrax
So, I'm getting myself a shiny new DD water cooling system, but I have a few questions about some of the componets.
The parts of the system are:
Copper TDX water block
MAZE4 GPU
MAZE4 chipset block
120mm Black Ice Xtreme
D4-12V pump
and 10ft of UV Blue, 1/2" tubing
(The resivior isn't from DD)
Now, will one 120mm Black Ice Xtreme be able to effectively cool 3 water blocks? Will the D4-12V pump be powrfull to push/pull the coolant that far? And is the UV Blue tubing any good? I'd rather get the Tygon tubing and add some UV dye to the mixture, but I don't know if the UV Dye will react in a bad way with....say Water Wetter, MCT-40/MCT-5, or any of the other anti-corrosion/anit-growth...will it?
Thanks
