The only difference I can tell physically, is that the Planar is 17.4" while the Sceptre is 17". But look at the casing - it is IDENTICAL.
Planar vs. Sceptre
Look at the way the base is shaped - the arrangement of buttons - the way the sides of the casing both taper horizontally, but not vertically. Do Planar and Sceptre simply use the same casing, or is there more of a relationship between the two companies?
Planar vs. Sceptre
