Originally posted by: YOyoYOhowsDAjello
Section 3.1 and 3.2 of my sticky thread has info about calibrating and setting up your system for better results.
Good read. Just glazed over it at the moment. Will definitely be working towards that guide over the next month.
I just remounted my GPU cooler to install an Audigy2, it works so much better. 24bit output through winamp sounding much better on all ends of the spectrum
Indeed the 24bit isnt the reason it sounded better. But I did test with Audacity and it actually will do 20kHz now (wouldn't before, guessing limitation of the onboard sound)
Lets see if I understand
Crossover at 80 on reciever will mean P162 will do 80-20kHz
It then sends all signal to subwoofer, where it's crossover will tell it to do 25-150Hz
OR does the sub do 25-80Hz?
Should I set the Fronts to "Large" or "Small"
Would there be any point to using coaxial digital output from the sound card? It would be using the same stereo mini -> RCA cable that I am using right now to output analog
Originally posted by: herm0016
i have p150's and a ps10. i send full signal to the speakers and let the internal, 4th order crossovers work. i then use the pre-outs for the left/right to send to the sub. the sub crossover is around 95 hz. this seems to work very well for my room.
On top of the hutch probably wouldn't be a good idea. You'd be way off-axis then which wouldn't be desirable.
The shelf idea could work though. It may or may not sound better with the speakers farther apart. You probably didn't get much chance to play around with the distance between your speakers due to the setup of the desk, eh?
Yeah it is really limiting me (but it is a great desk). The owner's manual reccomends 6ft apart too
If I did the shelf idea it would be able to maintain ~6ft seperation with a equilateral triangle to my seating position.
That seems a rather odd way to do it... why don't you just connect the sub up to the sub preout.
